BMW R850R user manual
roman.mih83
Beitrag von roman.mih83 »
Hello,
I have bought a second hand R850R and i can t fina a user manual. I have found and downloaded service manuals. I need to know the ABS sequence for the dashboard lights.
BEst regards,
Mihai
kboe
Modell: gar nix momentan
Re: BMW R850R user manual
Beitrag von kboe »
ABS problems shortly after start are very often due to a bad battery.
Start the engine. Drive a few meters. All ABS lamps should stop blinking. If not, drive a few minutes / kilometres until the engine is warm.
Stop and switch off engine. Start again. If then the ABS lamps stop blinking after a few metres your battery is probably weak.
On cold engine start the voltage drops below 10 V during start and ABS goes into error.
On warm engine start the voltage may not drop below 10 V and ABS will signal OK afterwards.
See here in English:
http://www.ibmwr.org/r-tech/oilheads/AB ... ndex.shtml
Kind Regards
Bernhard
roman.mih83
Thank you.
YEs, the battery is weak, it can t start the engine anymore. I will take it out and charge it for now and buy a gel battery later...
roman.mih83
Danke schon...
